How to check if DocumentObject is still in memory?
I created an event listener addin for Inventor.
Various events can be a reason to execute an iLogic rule. Some consecutive iLogic rules are necessary here. The rest I filter out early. These Rules are largely checkpoints to see if iProperties and Variables are still formatted correctly.
Because I noticed the behavior where short consecutive RunRuleWithArgument commands were ignored because a previous Rule had not yet finished, I created a Queue. Later even a (perhaps unnecessary) ConcurrentQueue. Events now add an Element (consisting of DocumentObject, EventDescription and RuleName) to this Queue.
A TimerEvent checks at one-second intervals whether there are still elements in the queue and starts the RuleRunner if it is ReadyForWork (and at least 1 document is active).
This works quite well, except when (or actually after) closing a document. Here a (before)-OnSaveDocument-event is triggered which, probably due to the single thread character, cannot be executed anymore before the document is closed, but is only processed when a document is active again.
So at the time of the event, DocumentObject IsNot Nothing, but when processing the Queue, this DocumentObject is no longer in memory.
I had hoped to find out if the document still existed by querying the DisplayName of the Object in a simple Try...Catch...End Try, but the Object itself has this information available.
My question is how can I find out if the DocumentObject is still present in Inventor memory (so that I can dequeue it without further actions while processing the Queue)?
Thanks, René
Inventor 2023.5.1
René van der Starre
