.addin missing from CustomCommand SDK sample
tyler.warner
tyler.warner
I would like to interact with CustomCommand sample that is included within the Inventor SDK samples. The Readme.txt says to copy the .dll & .addin but there is no .addin installed on my computer from the DeveloperTool.msi install.
I tried just creating a .addin file for it but it stays unloaded within the add-in manager. Tried changing the supported version within this file to be older but same result.
I'm using VS2022 & Inventor 2022.
C:\Users\Public\Documents\Autodesk\Inventor 2022\SDK\DeveloperTools\Samples\VCSharp.NET\AddIns\Custo...
Did this file properly install for anyone else or is anyone able to get the sample working?
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
tyler.warner
Made the .addin that works. This was for the C# sample.
<?xml version="1.0" encoding="utf-8"?>
     <!-- Type attribute is same as Type registry key (Standard, Translator, Plugin (Server only) -->
     <Addin Type="Standard">
     <ClassId>{140918FF-668A-435a-BD5E-57EF81CA5C5D}</ClassId>
     <ClientId>{140918FF-668A-435a-BD5E-57EF81CA5C5D}</ClientId>
     <!-- Both of the following fields should be translated. NO OTHER FIELDS SHOULD BE TRANSLATED! -->
     <DisplayName>CustomCommand</DisplayName>
     <Description>CustomCommand</Description>
     <!-- Assumes that CustomCommand.dll is underneath Inventor\bin -->
     <Assembly>CustomCommand.dll</Assembly>
     <SupportedSoftwareVersionGreaterThan>17..</SupportedSoftwareVersionGreaterThan>
     <LoadOnStartUp>1</LoadOnStartUp>
     <Hidden>0</Hidden>
</Addin>
JelteDeJong
You can use this .addin file text:
	<OSType>Win64</OSType>
	<LoadAutomatically>1</LoadAutomatically>
	<UserUnloadable>1</UserUnloadable>
	<Hidden>0</Hidden>
	<SupportedSoftwareVersionGreaterThan>19..</SupportedSoftwareVersionGreaterThan>
	<LoadBehavior>0</LoadBehavior>
	<DataVersion>1</DataVersion>
	<UserInterfaceVersion>36</UserInterfaceVersion>
	<!-- The following elements are set by the add-in installation. -->
	<Description>CustomCommand example</Description>
	<Assembly>C:\Users\Public\Documents\Autodesk\Inventor 2022\SDK\DeveloperTools\Samples\VCSharp.NET\AddIns\CustomCommand\bin\Debug\CustomCommand.dll</Assembly>
</Addin>
place it in the folder:
%ALLUSERSPROFILE%\Autodesk\Inventor Addins\
You also need to change some project settings:
- you should set the startup application to Inventor
and uncheck the following
also, remove everything here:
Most of this information can also be in my tutorial about creating an addin.
Jelte de Jong
Blog: hjalte.nl - github.com
