Add new properties to partlist iLogic
DFogliazza
DFogliazza
The problem I have is to add new properties to an .idw file partlist using iLogic.
The same you do double-clicking on partlist, "Add columns" selection, "New properties".
The properties are "Inventor User Defined Properties" inside the .ipt/.iam files
The problem is that I can't get the right PropId to use inside
oPartslist.PartsListColumns.Add(PropertyTypeEnum.kFileProperty, , oProp.PropId)
Any chance someone has the code to do it?
JhoelForshav
Hi @DFogliazza
You can use the name of the property as PropertyIdentifier 🙂
So for example if you have a custom property named "Test" you can write it like this:
oPartsList.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, , "Test")
