Add information to revision table, and toggle visibility of rows.
C_Haines_ENG
C_Haines_ENG
Im looking to use iLogic to add a revision to my revision table, and toggle the rows visibility. (See image below)
So you would run the command, and it would add a new revision and make sure the visibility is toggled on.
A.Acheson
Here is a rule that does what your requesting and a little more. Likely now need to ensure visibility is on as this is automatic. But you can do so by selecting the row object and visibility.
Regards
Alan
