How to Add a ribbon button with click mode pressed behavior in ribbon panel ( Ribbon item )
abdechafi.neji
abdechafi.neji
I'm using the inventor APi and I would like to add a custom ribbon button (ribbon item ) to my ribbon Panel , once the user clicks on the button , it should be pressed , and when click on another button it should be pressed and the first button should be released.
How can I achieve this?
        private void CreateButtonRibbonPanel(RibbonPanel ribbonPanel, List<CommadProperties> commandButtonPropList)
            if (ribbonPanel != null && commandButtonPropList.Count > 0)
                for (int i = 0; i < commandButtonPropList.Count; i++)
                    BtnIndex++;
                    commandButtonPropList[i].SetProperties();
                    CreateButtonToSamePanel(ribbonPanel.CommandControls, commandButtonPropList[i].CommandImage, commandButtonPropList[i].CommandName, commandButtonPropList[i].CommandClientId);
        private void CreateButtonToSamePanel(CommandControls CmdCtrlsForOnePanel, string ImageName, string DisplayName, string ClientID)
            if (m_CommandMgr == null || m_CtrlDefs == null || CmdCtrlsForOnePanel == null)
                return;
            stdole.IPictureDisp standardIconIPictureDisp = null;
            if (ImageName.CompareTo("") != 0)
                string Rooticon = Path.Combine(ResourcesDir, ImageName);
                Bitmap standardbitmap = new Bitmap(Rooticon);
                standardIconIPictureDisp = PictureDispConverter.ToIPictureDisp(standardbitmap);
            else
            object vtAddInId = ClientID;
            ButtonDef = null;
            string InternalName = DisplayName + BtnIndex.ToString();
            ButtonDef = m_CtrlDefs.AddButtonDefinition(DisplayName, InternalName, CommandTypesEnum.kQueryOnlyCmdType, vtAddInId, DisplayName, DisplayName,
                standardIconIPictureDisp, standardIconIPictureDisp, ButtonDisplayEnum.kDisplayTextInLearningMode);
            if (ButtonDef != null)
                _ButtonDefEvents = new ButtonDefEvents(this, BtnIndex);
               CommandControl CmdCtrl = CmdCtrlsForOnePanel.AddButton(ButtonDef, true, true, "", false);
                if (CmdCtrl != null)
CattabianiI
CattabianiI
You should manage the property in the buttonDefinition.OnExecute event. With a global variable to store the previous button to unpressed.
If you do not have a OnExecute handler you could try to set the Pressed property in the UserInputEvents.OnActivateCommand event.
abdechafi.neji
That's what I did after adding other codes with the using of ButtonDefs OnExecute event, but I'm just search for another solution that is integrated with the Inventor API , what I'm talking about is something like this :
https://stackoverflow.com/questions/1846647/wpf-ribbon-change-main-content-when-ribbontab-is-selecte...
I mean that ribbon buttons will be ribbon items , and it will be have the same behavior of items , Datagrid row ...
