Add folder above current working folder folder using iLogic
Daniel_Gerssen
Daniel_Gerssen
I want to create a folder \Export in the folder above my current working directory.
How do I manipulate the path in order to go one folder up.
For example: C:\path\Drawings\Inventor
to:
C:\path\Drawings\Export
	Dim oPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName)
	Dim oFolder As String = oPath & "\Export"
	If Not System.IO.Directory.Exists(oFolder) Then
	    System.IO.Directory.CreateDirectory(oFolder)
Curtis_Waguespack
Hi @Daniel_Gerssen
Give this a try:
Imports System.IO
Dim oFolder As String = System.IO.Path.GetDirectoryName(ThisDoc.Document.FullFileName)
Dim oParentFolder = Directory.GetParent(oFolder).FullName
Dim oNewFolder As String = oParentFolder & "\Export"
If Not System.IO.Directory.Exists(oNewFolder) Then
	System.IO.Directory.CreateDirectory(oNewFolder)
I hope this helps.
Curtis
