Add entry to menu
Add entry to menu
GeorgK
Advisor Advisor
Add entry to menu
GeorgK
Hello together,
how could I add an entry in this menu (rmb on the file)? Is there any sample code for it?
Georg
adam.nagy
Autodesk Support
Autodesk Support
Hi Gerg,
There does not seem to be an API for this - I logged it as a wish, id 78660
In the meantime you might be able to achieve it using the Windows API.
Cheers,
Adam Nagy
Autodesk Platform Services
GeorgK
Hello Adam,
do you have a sample to achieve this?
Georg
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
Sorry, I don't have one specific to this, but basically you would probaly need to use a Windows HOOK to monitor when a Menu pops up, then modify its content.
This sample that clicks on dialogs that pop up is following the same principle:
http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
I hope this helps.
Cheers,
Adam Nagy
GeorgK
Hello Adam,
thanks for your help.
Georg
