After Running macro and then select part or Assemblies to Suppress
The code below is working fine for selecting 3 parts and suppress it.
First i need to run macro and then select parts and assemblies as per my requirement by using mouse in the Inventor and then suppress it.
Can anyone please help me
' To suppress a part
Public Sub AssemblyCount()
    ' Set reference to active document.
    ' This assumes the active document is an assembly
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim selset As SelectSet
    Dim compOcc As ComponentOccurrence
    oDoc.SelectSet.Clear
    MsgBox ("Select a Part or a Subassembly")
    Do Until oDoc.SelectSet.Count = 3
        DoEvents    ' Yield to other processes.
    Loop
    Set selset = oDoc.SelectSet
    Dim obj As Object
    For Each obj In selset
        If TypeOf obj Is ComponentOccurrence Then
               Set compOcc = obj
               compOcc.Suppress
    Next
End Sub
But i want to select multiple parts until i hit enter button after hitting enter button all the selected parts must be suppressed
I tried the Application.onkey
Public enterWasPressed As Boolean
    enterWasPressed = False
    Do Until enterWasPressed = True
        Application.OnKey "{ENTER}", "recordEnterKeypress"
    Loop
    Dim obj As Object
               Set compOcc = obj
               compOcc.Suppress
    Next
End Sub
Sub recordEnterKeypress()
End Sub
but i am getting runtime error '424' object required can anyone please help me to fix my issue
adam.nagy
Autodesk Support
Autodesk Support
This seems like a duplicate of http://forums.autodesk.com/t5/inventor-customization/suppress-multiple-part-using-vba/m-p/5680580#U5...
Please do not log the same things multiple times, instead you can just update them.
Adam Nagy
Autodesk Platform Services
