Add dimensions To fully constrain the circle Using AddTwoPointDistance, i am not able to give the dimension to the circle
pranaykapse1
pranaykapse1
Dim WorkPlaneAngle As Double = (45 / 180) * PI
Dim ExtrusionRadius As Double = 50 ' Radius of the circle
Dim Location_XDirection As String = 50 ' Distance from origin in X direction
Dim Location_YDirection As String = 40 ' Distance from origin in Y direction
Dim oDimPt As Point2d
oDimPt = ThisApplication.TransientGeometry.CreatePoint2d(Location_XDirection, Location_YDirection)
' Get the component definition of the part
Dim oCompDef As PartComponentDefinition
oCompDef = ThisDoc.Document.ComponentDefinition
' Automatically select the Z axis
Dim oAxis As WorkAxis
oAxis = oCompDef.WorkAxes.Item("Z Axis")
' Automatically select the YZ plane
Dim oPlane As WorkPlane
oPlane = oCompDef.WorkPlanes.Item("YZ Plane")
' Create a new work plane at an angle to the YZ plane around the Z axis
Dim oNewPlane As WorkPlane
Try
    oNewPlane = oCompDef.WorkPlanes.AddByLinePlaneAndAngle(oAxis, oPlane, WorkPlaneAngle)
Catch ex As System.Runtime.InteropServices.COMException
    MessageBox.Show("Error creating plane: " & ex.Message)
End Try
' Create a new sketch on the new work plane
Dim oSketch As PlanarSketch
oSketch = oCompDef.Sketches.Add(oNewPlane)
' Draw a circle with a specified radius and center point
Dim oTransGeom As TransientGeometry
oTransGeom = ThisApplication.TransientGeometry
Dim oCenterPoint As SketchPoint
oCenterPoint = oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(Location_XDirection, Location_YDirection))
Dim oCircle As SketchCircle
oCircle = oSketch.SketchCircles.AddByCenterRadius(oCenterPoint, ExtrusionRadius)
 'Add dimensions To fully constrain the circle Using AddTwoPointDistance
' i am not able to give the dimension to the circle Dim oDimX As DimensionConstraint oDimX = oSketch.DimensionConstraints.AddTwoPointDistance(oCenterPoint, oSketch.OriginPoint, DimensionOrientationEnum.kHorizontalDim, oDimPt) Dim oDimY As DimensionConstraint oDimY = oSketch.DimensionConstraints.AddTwoPointDistance(oCenterPoint, oSketch.OriginPoint, DimensionOrientationEnum.kVerticalDim, oDimPt) Dim oDimRadius As DimensionConstraint oDimRadius = oSketch.DimensionConstraints.AddRadius(oCircle, oTransGeom.CreatePoint2d(Location_XDirection, Location_YDirection)) ' Create a profile Dim oProfile As Profile oProfile = oSketch.Profiles.AddForSolid 'Create an extrusion oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation) oExtrudeDef.SetDistanceExtent(1, kNegativeExtentDirection) Dim oExtrude As ExtrudeFeature oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
Stakin
Try it
I add
Dim oOrigin As SketchPoint
oOrigin = oSketch.SketchPoints.Add(oTransGeom.CreatePoint2d(0, 0))
oSketch.GeometricConstraints.AddGround(oOrigin)
and modify  the osketch.originpoint to oOrigin.
Try
    oNewPlane = oCompDef.WorkPlanes.AddByLinePlaneAndAngle(oAxis, oPlane, WorkPlaneAngle,True)
End Try
oDimX = oSketch.DimensionConstraints.AddTwoPointDistance(oCenterPoint, oOrigin, DimensionOrientationEnum.kHorizontalDim, oDimPt)
oDimY = oSketch.DimensionConstraints.AddTwoPointDistance(oCenterPoint, oOrigin, DimensionOrientationEnum.kVerticalDim, oDimPt)
' Create a profile
