Get full document name of sub assy by picking model leader note
tim11_manhhieu
tim11_manhhieu
Can i get full path of sub assy NDA006848.iam when i pick ① leader note?
Option Explicit
Sub yyyyyyy()
Dim oLeader As ModelLeaderNote
Set oLeader = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kModelAnnotationFilter, "Select: ")
End Sub
Stakin
Stakin
Sub Main()
	Dim oSS As SelectSet= ThisApplication.ActiveDocument.SelectSet
	oSS.Select(ThisApplication.CommandManager.Pick(SelectionFilterEnum.kModelAnnotationFilter, "Select a ModelAnnotation"))
	Dim  oNote As ModelLeaderNote = oSS.Item(1)
	 Dim oOccEnumerator As ComponentOccurrencesEnumerator
	 oOccEnumerator = oNote.Definition.Intent.Geometry.ContainingOccurrence.OccurrencePath
	 Dim oFullFileName As String
	 oFullFileName=oOccEnumerator(1).Definition.Document.FullFileName
	 MessageBox.Show("1st Level Occ(Part/Sub Asm) Name:" & oOccEnumerator(1).Name & vbLf &
	 			"1st Level Occ(Part/Sub Asm)  FileName:" & oFullFileName & vbLf &
	 			"Leaf Occurrence(Part) Name:" & oOccEnumerator(oOccEnumerator.Count).Name & vbLf &
	 			"Leaf Occurrence(Part) FileName:" & oOccEnumerator(oOccEnumerator.Count).Definition.Document.FullFileName, "oNote associate")
End Sub
tim11_manhhieu
Appreciate it.
VBA for who need.
Option Explicit
Sub xxx()
Set oNote = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kModelAnnotationFilter, "Select: ")
Set oOccEnumerator = oNote.Definition.Intent.Geometry.ContainingOccurrence.OccurrencePath
oFullFileName = oOccEnumerator(1).Definition.Document.fullFilename
Debug.Print oFullFileName
End Sub
