How to get Bend Order Annotation information using iLogic/VBA
Aidarhanovn
Aidarhanovn
Hi!
Is it possible to programmatically access Bend Order Annotation information using iLogic or VBA in Autodesk Inventor?
I’m looking to find out if there’s a way to get this data through the API, perhaps from the Flat Pattern, and whether it’s possible to extract things like the bend number
I’d appreciate any tips, code examples, or links to relevant documentation
johnsonshiue
Hi! You may want to take a look at FlatBendResult object in Inventor API. There are GetBendOrder and SetBendOrder methods.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-FlatBendResult
Many thanks!
Software Test Engineer
