Hi Manfred,
Do you use User Control in dockable window?
Because if you use User control for design that dockable window, an property grid is only a component on there, you can create context menu for user control and filter insiders.
You can check this link to see how you can create a context menu and filter it according to objects....
I also sharing the code in that page
private void MyPopupEventHandler(System.Object sender, System.EventArgs e)
// Define the MenuItem objects to display for the TextBox.
MenuItem menuItem1 = new MenuItem("&Copy");
MenuItem menuItem2 = new MenuItem("&Find and Replace");
// Define the MenuItem object to display for the PictureBox.
MenuItem menuItem3 = new MenuItem("C&hange Picture");
// Clear all previously added MenuItems.
contextMenu1.MenuItems.Clear();
if(contextMenu1.SourceControl == textBox1)
// Add MenuItems to display for the TextBox.
contextMenu1.MenuItems.Add(menuItem1);
contextMenu1.MenuItems.Add(menuItem2);
else if(contextMenu1.SourceControl == pictureBox1)
// Add the MenuItem to display for the PictureBox.
contextMenu1.MenuItems.Add(menuItem3);
Regards
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
