Add Context Menu to Dockable Window
M.Zirk
M.Zirk
is it posiible to add a context menu to a dockable window?
I use a propertygrid control as child in a dockable window.
Regards
Manfred
Dev_rim
Hi Manfred,
Do you use User Control in dockable window?
Because if you use User control for design that dockable window, an property grid is only a component on there, you can create context menu for user control and filter insiders.
You can check this link to see how you can create a context menu and filter it according to objects....
I also sharing the code in that page
private void MyPopupEventHandler(System.Object sender, System.EventArgs e)
    // Define the MenuItem objects to display for the TextBox.
    MenuItem menuItem1 = new MenuItem("&Copy");
    MenuItem menuItem2 = new MenuItem("&Find and Replace");
    // Define the MenuItem object to display for the PictureBox.
    MenuItem menuItem3 = new MenuItem("C&hange Picture");
    // Clear all previously added MenuItems.
    contextMenu1.MenuItems.Clear();
    if(contextMenu1.SourceControl == textBox1)
       // Add MenuItems to display for the TextBox.
       contextMenu1.MenuItems.Add(menuItem1);
       contextMenu1.MenuItems.Add(menuItem2);
    else if(contextMenu1.SourceControl == pictureBox1)
       // Add the MenuItem to display for the PictureBox.
       contextMenu1.MenuItems.Add(menuItem3);
Regards
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
M.Zirk
Hello Devrim,
thank you for reply and the sample.
I will try this.
Manfred
