Automating Drawing Sheet
raymaster
raymaster
Hello All
I have an iparts factory, which I created a sheet for one of its members containing all the dimensions and annotations needed, but once I need to do this for the rest of the members, I need to go through a process of ( copy sheet, paste sheet, double click the base view and change to the next member, then rename the sheet according to the member name, recenter the view and fitting it).
1. I need a rule to automate the process mentioned, mainly:
  • get a new sheet
  • change to the next member of the main base view
  • rename sheet according to member's name
2. I need a rule to update all the sheets and the contained views and parts
3. I need a rule to control which bodies are visible and which are hidden
THANX IN ADVANCE
Best
A.Acheson
Item 3 should be carried out in the factory member itself. Controlling solids on the drawing has inconsistent behavior in my previous expierience.
Can you please attach a code attempt if you have allready began this workflow?
A quick search of previous examples shows most people place ipart members in there own document which is a little easier to work with. Here is one search
Regards
Alan
raymaster
Thank you for your contribution, but this wasn't what I needed.
I need a rule to control which bodies are visible and which are hidden, as I couldnt find a way to control this using the iparts table columns, as like Compute and Suppress feature, neither an iLogic code.
Best
A.Acheson
Multi body solids in iparts do not work well together. Can you carry out the workflow manually, If so can you supply the steps?
Regards
Alan
