Add all faces directly adjacent to the faces of the selected Feature to a List(Of Face)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I need the solution that adds all faces directly adjacent* to the faces of the selected PartFeature to a List(Of Face).
I'm using iLogic like this:
Imports System.Linq
AddReference "System.Core"
Dim AllFaces As New List(Of Face)
Dim oIPT As PartDocument=ThisDoc.Document
Dim oCD As ComponentDefinition=oIPT.ComponentDefinition
Dim oFtr As PartFeature
Dim MsgBody As String
While Answer<>vbCancel
	AllFaces.Clear
	MsgBody=""
	oFtr = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "")
	AllFaces.AddRange(From f As Face In oFtr.Faces Select f)
	MsgBody &= "The feature faces QTY = " & AllFaces.Count & vbCrLf
'	AllFaces.AddRange ???
	MsgBody &= "Faces Selected in Total = " & AllFaces.Count & vbCrLf
	Answer=MsgBox(MsgBody & vbCrLf & "Select another feature?", MsgBoxStyle.OKCancel,"Face selection for """ & oFtr.Name & """:")
End While
... and need some hint for the commented line.
* I'm not 100% sure that word "adjacent" suits this case. Under adjacent face i mean face that touches the given one (has common edge or vertex). Maybe "CoFace" is more suitable word for this?
Please vote for Inventor-Idea Text Search within Option Names
JhoelForshav
Hi @Maxim-CADman77
I think something like this is what you're looking for? 🙂
Dim oFeature As PartFeature = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "")
For Each oFace As Face In oFeature.Faces
	For Each oEdge As Edge In oFace.Edges
		For Each eFace As Face In oEdge.Faces
			If oFeature.Faces.OfType(Of Face)().Where(Function(x) x Is eFace).Count = 0 _
				Then AllFaces.Add(eFace)
		Next
	Next
Next
'Test to see that the correct faces are selected
For Each oFace As Face In AllFaces
ThisDoc.Document.SelectSet.Select(oFace)
Next
