use ilogic to replace the text of existing leader note
omvcilindri
Message 1 of 9
omvcilindri
Hi everyone
I have a question propose, I would like  replace  text of  existing   Leader Note  with a new text  through ilogic , but the code does not work, can someone help me find the error.
I want  replace  "P9" in "N9"
 code :
If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
        MessageBox.Show("This rule only works in a drawing document.", "Change Leader Text",MessageBoxButtons.OK,MessageBoxIcon.Error)
        Return
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oLeaderNote As LeaderNote
Dim TXT2Find As String
Dim NewTXT As String
saveOriginalText = False
addDescription = False
Question = MessageBox.Show("Overwrite existing leader text?", "Change Leader Text",MessageBoxButtons.YesNoCancel,MessageBoxIcon.Question,MessageBoxDefaultButton.Button1)
Select Case Question:
Case vbYes
Case vbNo
        saveOriginalText = True
Case vbCancel
        Return
End Select
oDescription = NewTXT
'get user input
TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
'look for blank value
If TXT2Find ="" Then
Return 'exit rule
Else
'Continue rule
NewTXT = InputBox("Enter Text To Replace   '"& TXT2Find _
& "'  with.", "iLogic", "****")
oSheets = oDoc.Sheets
For Each oSheet In oSheets
    Try
    oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
    'look at gerenal notes
    For Each oGeneralNote In oGeneralNotes
        If oGeneralNote.FormattedText = TXT2Find Then
        oGeneralNote.FormattedText = NewTXT
        Else
    Next
        Catch
oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
    For Each oLeaderNote In oLeaderNotes
        If oLeaderNote.FormattedText = TXT2Find Then
        oLeaderNote.FormattedText = NewTXT
        Else
               Next
               End Try
    Next
For Each oLeaderNote In oDoc.ActiveSheet.DrawingNotes
        'saves the original text
        originalText = oLeaderNote.FormattedText
        oLeaderNote.FormattedText = oDescription
        'adds original beginning to end of label text if applicable
        If saveOriginalText = True Then
               oLeaderNote.FormattedText = oLeaderNote.FormattedText & vbCr & originalText
Next
Replies (8)
Message 2 of 9
WCrihfield
Are you familiar with formatted text?  They can get complicated, because they use XML tags within, to represent linked/live iProperties & parameters.  You may want to replace the regular text instead of the formatted text.
Here is an example code using the regular text.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
	Return
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim saveOriginalText As Boolean = False
Dim addDescription As Boolean = False
Question = MsgBox("Overwrite existing leader text?",vbYesNoCancel + vbQuestion + vbDefaultButton1, "Change Leader Text")
Case vbYes
Case vbNo
Case vbCancel
	Return
End Select
Dim TXT2Find As String = InputBox("Enter Text To Find:", "iLogic")
If TXT2Find = "" Then
	MsgBox("Text to find was blank, so exiting.",vbOKOnly," ")
	Return
Dim NewTXT As String = InputBox("Enter Text To Replace   '" & TXT2Find & "'  with.", "iLogic")
If oNewTXT = "" Then
	MsgBox("Text to replace original was blank, so exiting.", vbOKOnly, " ")
	Return
Dim oLNotes As LeaderNotes
Dim oLNote As LeaderNote
For Each oSheet As Sheet In oDDoc.Sheets
	oLNotes = oSheet.DrawingNotes.LeaderNotes
	For Each oLNote In oLNotes
		If oLNote.Text = TXT2Find Then
				oLNote.Text = NewTXT & vbCrLf & oLNote.Text
			Else
	Next
Next
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 9
omvcilindri
Thanks for your help, I don't know the formatted text. Yes changing the regular text is fine, I only have to change the content of the text. I tested your code but it doesn't work, but the message you put is nice.
Message 4 of 9
JhoelForshav
Hi @omvcilindri
@WCrihfieldjust accidentially added an "o" in the parameter name NewTXT on the line:
The code works if you remove that:
	Return
Case vbYes
Case vbNo
Case vbCancel
	Return
End Select
	Return
If NewTXT = "" Then
	Return
			Else
	Next
Next
Message 5 of 9
JhoelForshav
I also noticed that if you dont overwrite the existing text it adds a line break to the text.
This makes it a bit difficult to find that text again since you only have one row in the inputbox.
Therefore i suggest this change to the code:
	Return
Case vbYes
Case vbNo
Case vbCancel
	Return
End Select
	Return
If NewTXT = "" Then
	Return
		Dim oTxt As String = oLNote.Text
		If oTxt.Contains(Chr(10)) Then oTxt = oTxt.Replace(Chr(10), " ")
		If oTxt = TXT2Find Then
			Else
	Next
Next
 It'll find the text even if there's a line break in it if you just use a simple blank space in the inputbox 🙂
Message 6 of 9
omvcilindri
nice job congratulations
Message 7 of 9
robertast
@JhoelForshav
I am constantly amazed at your abilities. Looking at your work, it seems that nothing is impossible for you 👍 👍👍
Message 8 of 9
danielvdeleito
Hi @JhoelForshav ,
Would you able to help me in something similar? I have callouts already showing some Iproperties. I need to add more Iproperties and custom properties to some of these callouts. Is any way to run and Irule to select only the callouts I need to add the information and do it automatically. Something similar to the "Match Properties" in AutoCAD.
Daniel V.
Message 9 of 9
JBEDsol
So I came across this attempting to do something similar.  I have a bunch of drawings where I need to change the leader text to the proper acronyms.  So SHT needs to change to SH to comply w/ the ASME convention.  I'm using VB so I can better troubleshoot.  The code seems to work but where ever there's a break (meaning text in 2 rows on top of eachother) the code overwrites that to be one line.  How do I correct this so the format remains the same?
Private Sub Replace_Text_Click(sender As Object, e As EventArgs) Handles Replace_Text.Click
If appApp.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("This rule only works for Drawing Documents.", vbOKOnly, "WRONG DOCUMENT TYPE")
Return
Dim oDDoc As DrawingDocument = appApp.ActiveDocument
'Question = MsgBox("Overwrite existing leader text?",vbYesNoCancel + vbQuestion + vbDefaultButton1, "Change Leader Text")
'Select Case Question:
'Case vbYes
' saveOriginalText = False
'Case vbNo
' saveOriginalText = True
'Case vbCancel
' Return
'End Select
MsgBox("Text to find was blank, so exiting.", vbOKOnly, " ")
Return
If NewTXT = "" Then
Return
If oTxt.Contains(TXT2Find) Then
oTxt = oTxt.Replace(TXT2Find, NewTXT)
appApp.ScreenUpdating = True
' Do Nothing
Next
Next
End Sub
