Add a Multi-Value iProperty to a Drawing
arkelec
arkelec
In parts & assemblies, I can add a multi-value parameter, add it to a form & select the value from there.
I want to do the same thing in a drawing.
Is this possible?
bradeneuropeArthur
You can also add parameters to a drawing yes.
So that means this should be possible.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Parameters are also available within the drawing.
So you can use the same principle.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
arkelec
Great, thanks.
For some reason, I thought that Parameters were not available in Drawings, probably because there was no ribbon icon by default.
