Access to the property field of the cartridge in vba
sebastien.forman
sebastien.forman
Hello everybody.
I would like to know if it is possible to access and modify the field of the property of the cartridge.
As shown in the screencast.
This field is currently editable when the drawing is created.
I would like my vba code to fill it itself.
Thank you for your help.
bradeneuropeArthur
Call oDrawDoc.ActiveSheet.TitleBlock.SetPromptResultText(oDrawDoc.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(1), "This")
Call oDrawDoc.ActiveSheet.TitleBlock.SetPromptResultText(oDrawDoc.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(2), "That")
Call oDrawDoc.ActiveSheet.TitleBlock.SetPromptResultText(oDrawDoc.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(3), "and so on")
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sebastien.forman
something like that? (don't work)
edit: sorry i can not attach files for some bug reason
Sub updateiprop()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim Partnr As Property
Dim Desc As Property
Dim bx As Document
Set bx = b.ReferencedDocuments.Item(1)
MsgBox bx.FullDocumentName
Dim propset As PropertySet
Set propset = bx.PropertySets.Item("Design Tracking Properties")
Set Partnr = propset.Item("Part Number")
Set Desc = propset.Item("Description")
Dim Filen As String
Filen = b.DisplayName '"103-NiMo-10200-001 (Collection tank)" '
Dim strSp() As String
strSp = Split(Filen, " (")
MsgBox strSp(0)
MsgBox strSp(1)
Partnr.Value = strSp(0)
Desc.Value = Replace(strSp(1), ").idw", "")
Dim strSp2() As String
strSp2 = Split(Filen, "-")
MsgBox Filen
MsgBox strSp2(0)
Call b.ActiveSheet.TitleBlock.SetPromptResultText(b.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(1), "This")
Call b.ActiveSheet.TitleBlock.SetPromptResultText(b.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(2), "That")
Call b.ActiveSheet.TitleBlock.SetPromptResultText(b.ActiveSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(3), "and so on")
a.ActiveDocument.Save2 (True)
End Sub
bradeneuropeArthur
use this:
Sub changePrompt()
  Dim doc As DrawingDocument
  Set doc = ThisApplication.ActiveDocument
  Dim tb As TextBox
  Dim i As Integer
  i = 1
  Dim border As TitleBlock
  Set border = doc.ActiveSheet.TitleBlock
  Dim borderDef As TitleBlockDefinition
  Set borderDef = border.Definition
  For Each tb In borderDef.Sketch.TextBoxes 'oDrawDoc.Sheets.Item(i).TitleBlock.Definition.Sketch.TextBoxes.count
      If tb.Text = "<DEPARTEMENT>" Then
Call border.SetPromptResultText(tb, "this is your string")
      i = i + 1
  Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
sebastien.forman
thanks again bradeneurope
fortunately there are people like you to help beginners like me
I wish you a nice day.
Sébastien
bradeneuropeArthur
Did it solve the issue?
Your thanks are appreciated very much.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
sebastien.forman
yes that works perfectly XD
