Access the iLogic log externally
AlexFielder
Advisor Advisor
AlexFielder
Clearly my search-fu on these forums is deserting me today, but say for instance I have access to the iLogic addin externally, from another application - in this case PowerShell:
Is it possible to read (and therefore act upon) the output from the iLogic log- watching for "handled" or "unhandled" errors etc.
Thanks in advance.
Alex.
WCrihfield
Hi @AlexFielder.  I haven't messed with it much, but here are a few pointers from the iLogic side that you may or may not already be aware of.
'get or set a String
iLogicVb.Automation.LogControl.Folder
'ReadOnly String
iLogicVb.Automation.LogControl.FullFileName
'Sub, supply a String
iLogicVb.Automation.LogControl.SaveLogAs
'As Autodesk.iLogic.Interfaces.ExceptionsLog
Dim oELog As ExceptionsLog = iLogicVb.Automation.RuleExceptionsLog
oExs = oELog.Exceptions '(As IEnumerable)
As I'm sure you are aware, what you see after iLogicVb.Automation in an iLogic rule is similar to what will be available externally when you get the Automation object of the iLogic AddIn.  So, I'm hoping this will help a little.
Wesley Crihfield
(Not an Autodesk Employee)
AlexFielder
thanks @WCrihfield that looks like just the ticket. I shall report back with my findings 🙂
