2D drawing L+R
2D drawing L+R
2D drawing L+R
So i am practicing working with inventor and i just have a simple question about 2D drawings in general. I have a sheet metal part that will be attached to both sides of a table. The sheet metal part will be folded both ways. One way for the right side, and the opposite direction for the left side. I want to know how i can display this without making 2 different drawings  for the left and right side. Is it enough if i just put "L+R" in the drawing?
Thanks in advance.
Kind regards,
Gijs
Rob67ert
Hi there Gijs,
I always made one drawing of the left side and placed a text on it like; Left as drawing, Right as mirrored.
But sometimes did went wrong in production. Now i always make 2 drawings.
There is a workaround that this can be done with an iPart.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
