XmlReader
XmlReader
JoAntt
XmlReader
JoAntt
Hi
can i use XmlReader in ilogic?
i cant get it to work.
Imports System.Xml
Imports System.IO
Dim reader As XmlTextReader = New XmlTextReader(pathToXMLfile)
frederic.vandenplas
Does this work? i don't get any errors, but i did not tested this further
Dim xmlDoc As Object
 xmlDoc = CreateObject("Msxml2.DOMDocument.6.0")
xmlDoc.Load(xmlFileName)
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
JoAntt
No, cant get it to work
MechMachineMan
Here is a sample of an xml reader that i messed around with a got to a working point:
AddReference "System.Linq"
AddReference "System.Xml"
AddReference "System.Xml.Linq"
AddReference "System.Core"
Imports System.Linq
Imports System.Xml
Imports System.Xml.Linq
Imports System.Xml.Schema
 Class FunctionalClass
     Shared FeedXML As XDocument
    Sub Main()
            FeedXML= XDocument.Load("C:\Users\Owner\Desktop\Test File.xml")
            For Each oElement As XElement In FeedXML.Descendants("config")
                MsgBox(oElement)
            Next
'            For Each oNode As XNode In FeedXML.<config>.Nodes
'                MsgBox(oNode)
'            Next
'                MsgBox(oNode)
'            Next
'            For Each oElement As XElement In FeedXML.<config>.Elements
'                MsgBox(oElement)
'            Next
'            oNumber = FeedXML.<config>.<store>.<Number>.Value
'            emailbody = FeedXML.<config>.<emailsettings>.<emailbody>.Value
'            MsgBox(String.Format("Number={0}", oNumber) & vbLf & String.Format("emailbody={0}", emailbody))
    End Sub
End Class
SAMPLE XML FILE INFO saved as  "C:\Users\Owner\Desktop\Test File.xml"
<?xml version="1.0" encoding="UTF-8"?>
<config>
    <store>
          <Number>NumberValue</Number>
    </store>
    <emailsettings>
          <emailbody>EmailBodyValue</emailbody>
    </emailsettings>
</config>
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
