2021.1 Update slows down loading of ilogic forms.
D0UGLAS
Message 1 of 9
D0UGLAS
Autodesk can this be fixed as soon as possible?
Replies (8)
Message 2 of 9
Scott.Hallmark
I posted about this on Friday. This has to be addressed by ADSK asap.
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
Message 3 of 9
MjDeck
This is issue number INVGEN-43789. We should be able to fix it soon.
Mike Deck
Software Developer
Message 4 of 9
D0UGLAS
Hi Mike, I do not know if it could be related, but the forms editor is also acting up.
Message 5 of 9
MjDeck
@D0UGLAS , can you give more details about problems in the form editor?
Because of the slow forms, changes you make in the form editor will also run more slowly. You might see it building the form piece by piece after every change.
Mike Deck
Software Developer
Message 6 of 9
D0UGLAS
Yes Mike,
I only added a single parameter to form, then it hung up for a long time before it appeared.
When I tried to scroll up through the form in the editor, the displayed form flickered many times in a way which reminded me of having the parameters set to recalculate after every change and not when requested.
This slowdown for the moment has stopped me from using the form, I change the parameters in the parameter editor, so I hope these observations help.
Douglas
Message 7 of 9
MjDeck
I'm pretty sure that's caused by the same problem (which is INVGEN-43789).
Every time you add a new parameter or other item, iLogic has to redraw the form. In 2021.1, that is taking much longer. And while the form is being drawn, you may see controls being moved around.
Mike Deck
Software Developer
Message 8 of 9
D0UGLAS
Hi Mike,
How are AUTODESK getting on with this? INVGEN-43789
Waiting for forms to load is agony and somewhat defeats their objective.
Kind Regards
Douglas
Message 9 of 9
D0UGLAS
Seems this was solved by INVGEN-44234 release 2021.1.1 Update.
