10 mm steps
10 mm steps
martinhoos
10 mm steps
martinhoos
Hello all,
i have a user parameter called "length", this parameter shouldt only works in 10 mm steps. if not a message appears. Is there anybody who can help me with this Problem?
Thanks in advance
Regards
Martin
Owner2229
Here you go:
Paste this to a new rule and test it out by changing the parameter:
s = length
Dim oVal As Double = Parameter("length")
If (oVal Mod 10) = 0 Then Exit Sub
MsgBox("Parameter 'length' must be a multiple of 10." & vblf & "Current value: " & oVal )
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
martinhoos
Thank you very much, Mike! It runs....  🙂
