How to do a SplitFaces with VB / Api?
HermJan.Otterman
Advisor Advisor
HermJan.Otterman
I want to do a split of a worksurface, with a sketchblock (can also be a normale sketch)
with my code, Inventor 2017 is crashing.
and when not crashing, VB will give me an error.
what am I missing here?
thanks!
my code:
Private Sub CreatesplitHole()
Dim oPartDoc As Inventor.PartDocument = _inventorApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
'Dim oSelectSet As SelectSet = oPartDoc.SelectSet
Dim oSketch As PlanarSketch = oPartDoc.ComponentDefinition.Sketches(2)
Dim oTobjs As TransientObjects = _inventorApplication.TransientObjects
Dim objectCollection As ObjectCollection = oTobjs.CreateObjectCollection
Dim oWSFace As WorkSurface = oPartDoc.ComponentDefinition.WorkSurfaces(1)
Dim oSurfBody As SurfaceBody = oWSFace.SurfaceBodies(1)
Dim oFace As Face = oSurfBody.Faces(1)
objectCollection.Add(oFace)
Dim oSplitfeatures As SplitFeatures = oPartDoc.ComponentDefinition.Features.SplitFeatures
Dim oSketchBlocks As SketchBlocks = oSketch.SketchBlocks
For Each oSketchBlock As SketchBlock In oSketchBlocks
Dim oPath As Path = Nothing
Dim oSketchEntities As SketchEntitiesEnumerator = oSketchBlock.Definition.SketchEntities
For Each oSketchEntity As Object In oSketchEntities
If oSketchEntity.Construction = False Then
If oSketchEntity.Type <> ObjectTypeEnum.kSketchPointObject Then
oPath = oCompDef.Features.CreatePath(oSketchEntity)
Exit For
Next
Dim oSplit As SplitFeature
' Why does the split not work?
'oSplit = oSplitfeatures.SplitFaces(oPath, False, oSurfBody)
oSplit = oSplitfeatures.SplitFaces(oPath, False, objectCollection)
Next
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Owner2229
I've changed your code to work with normal sketch entities and it seems to work:
I've created a testing spline in your part, so you can test it out.
I can look in to the sketchblocks if you "need" to use them.
Private Sub CreateSplitHole()
    Dim oDoc As Inventor.PartDocument = _inventorApplication.ActiveDocument
    Dim oCD As PartComponentDefinition = oDoc.ComponentDefinition
    Dim oSketch As PlanarSketch = oCD.Sketches(2)
    Dim oTO As TransientObjects = _inventorApplication.TransientObjects
    Dim OC As ObjectCollection = oTO.CreateObjectCollection
    Dim oWSFace As WorkSurface = oCD.WorkSurfaces(1)
    OC.Add(oFace)
    Dim oPath As Object = Nothing
    For Each oSE As Object In oSketch.SketchEntities
        If oSE.Construction Then Continue For
        If oSE.Type = ObjectTypeEnum.kSketchPointObject Then Continue For
        oPath = oCD.Features.CreatePath(oSE)
        Exit For
    Next
    If oPath Is Nothing Then Exit Sub
    Dim oSplitFeatures As SplitFeatures = oCD.Features.SplitFeatures
    Dim oSplit As SplitFeature = oSplitFeatures.SplitFaces(oPath, False, OC)
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
HermJan.Otterman
THANKS!!
still don't see what I did wrong.
I thought it would be easier with a sketch block but apperently it is not.
I can manage with a normal sketch
thanks for your help!
Herm Jan
