Use iLogic to check for user parameter, create it, populate it
I am trying to get some simple iLogic code to run and I could use some (probably very basic) help.
Essentially, I need to complete my If/Then statement to do the functions in my comment quotes below.  I basically want to check for a parameter named 'PartNumber' in any existing document in which the user opens (and clicks 'Save' or updates iProperties).  If it exists, I want to assign it the 'MFPN' variable value (taken from the iProperties).  If it does not exist, I want to create it, then assign the 'MFPN' variable value to it.
Any help is appreciated greatly.  The simpler the solution the better, as I am very novice at understanding and/or maintaining programming code.
 Here's what I have...
iProperties.Value("Project", "Part Number") = ThisDoc.FileName(False) 'without extension
MFPN = iProperties.Value("Project", "Part Number")
If My_Expression Then
'If "PartNumber" parameter exists in this file, populate it with MFPN variable
Else
'If "PartNumber" parameter does not exist, create it, then populate it with MFPN variable
iLogicVb.UpdateWhenDone = True
Owner2229
Hey, you can't use a name with space as parameter name, hence: "Part_Number":
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oParas As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Dim oPara As UserParameter
Try
    oPara = oParas.Item("Part_Number")
Catch
    oPara = oParas.AddByValue("Part_Number", "", UnitsTypeEnum.kTextUnits)
End Try
Dim MFPN As String = ThisDoc.FileName(False) 'without extension
iProperties.Value("Project", "Part Number") = MFPN
oPara.Value = MFPN
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank you @Owner2229. I dont have the issue of parameter regenerating. I modify your code to have an inputbox but it doesnt change the value.
A_BracketL = InputBox("Enter DRV_A_BracketL Value", "Left Bracket Angle", 91.23)
Try
    oPara = oParas.Item("DRV_A_BracketL")
Catch
    oPara = oParas.AddByValue("DRV_A_BracketL", A_BracketL, UnitsTypeEnum.kDegreeAngleUnits) 'DRV_A_BracketL/57.29577951
End Try
JelteDeJong
try it this way.
Dim A_BracketL = InputBox("Enter DRV_A_BracketL Value", "Left Bracket Angle [Deg]", 91.23)
Try
Catch
    oPara = oParas.AddByValue("DRV_A_BracketL", 0, UnitsTypeEnum.kDegreeAngleUnits)
End Try
' create a number from the text.
Dim doubleValue As Double = Double.Parse(A_BracketL)
'inventor expects radians. convert the deg to rad.
'inventor will convert it back to Deg when that value is shown to the user.
doubleValue = doubleValue*(Math.PI/180)
oPara.Value = doubleValue
Jelte de Jong
Blog: hjalte.nl - github.com
Works perfectly @JelteDeJong . Thank you very much.
