Dear Developers,
many times I had trouble with the probe tool. I have attached an example below. Whenever turn on probes in a result file, and then switch views, you get multiple other probes lying above the original ones. Unfortunately it is not possible to delete or move single probes, you either delete all or none.
Another problem I encountered with the probe tools and undercuts. Since you can't use the view cut of inventor, you have to use the section cut in the result display. If you use this tool and you have an undercut, the probe tool frequently delivers the value of the not visible, already cut away parts, because they are from your point of view in front of the targeted position.
The third problem is, that I have had multiple crashes involving the probe tool. E.g picking probes (more than 4), changing views, dong this twice and then crashing.
These problems have made me use probes very seldomly and quickly deleting them again.
I would highly appreciate, if you improve the probe tool.
In case I am not using the tool right, please be so kind to advise me how to use it.
![Unbenannt.1PNG.PNG Unbenannt.1PNG.PNG](https://forums.autodesk.com/t5/image/serverpage/image-id/412685iC0CF39247F2D677D/image-size/large?v=v2&px=999)
![Unbenannt2.PNG Unbenannt2.PNG](https://forums.autodesk.com/t5/image/serverpage/image-id/412686i457E1E25FB92F902/image-size/large?v=v2&px=999)
Kind regards
Santino
