Add the ability to select the stiffness of a bond between two parts. For instance a window bonded in place with a flexible adhesive; if there was a gap between the window and the surface to which it was to be bonded the stiffness of the bond could be an input i.e. the modulus of the adhesive. Depending on the gap (adhesive) distance we would generate results and ideally be able to see the translation between the glass and the substrate to ensure that the adhesive elongation was not exceeded. This would reduce a lot of modelling of an adhesive joint.....
