Zero Stress On Shell Element in a shell/solid assembly
Message 1 of 17
Hi Everyone,
I am running a FE analysis of a structure, the shell part where the load is applied on, shows zero stress. Could anyone let me know what is the reason or what I am doing wrong?
Any comment is appreciated in advance. The shell and solid Von Mises results are presented in these photos.
Replies (16)
Message 2 of 17
Roelof.Feijen
Did you check the material properties of the shell idealization. Be sure not to use the Generic material property. The pictures shows a min / max value. Does the shell results maybe show a stress singularity on one node for example?
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 3 of 17
@Roelf.Feijen Thanks for your comment. I don't use generic material. a snapshot of shell material is added.
Message 4 of 17
Roelof.Feijen
Hi @Anonymous,
It is hard to tell what is going on, based on some images.
Could you share your model?
Roelof Feijen
Message 5 of 17
Hi @Roelof.Feijen ,
Not really. If you have such a problem in an analysis which areas do you check? what do you think could be the reason of this.
any thoughts?
Kind Regards,
Ali
Message 6 of 17
Roelof.Feijen
It is not so easy to give advise if I don’t understand your problem.
From the title of this post I thought that all shell results are zero. But I am right that there is only one node that has a zero value?
Also I don’t see a displacement value at the summary at the bottom of your results plots. Did you check the displacement results?
If it comes to stress note that by default we are looking at the average nodal results. Is your stress plot showing the average, the min, the max?
Roelof Feijen
Message 7 of 17
hi @Roelof.Feijen
The displacement is:
Stress distribution definition:
Thanks in advance,
Ali
Message 8 of 17
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
Are you sure that the 0 stress is in the shell? From your title, you have solids and shell elements. If I remember correctly (I am answering from home and do not have access to the software), I think the minimum value of 0 is in the solid, not the shell element.
In other words, it is possible that In-CAD displays a value of 0 in all of the solids because the solids do not have a "shell stress". If you edit the contour plot, choose "Part View", and select only the shell parts, then the minimum marker will show the true minimum value in the displayed parts.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 9 of 17
Hi @John_Holtz
I checked part view, but I don't know why I can not pick shells!!!. So that, I just used the probe to pick a node stress. The stress on shell element could be seen in the following snapshot which is almost 0:
Thanks for you comment John,
Ali.
P.S: Just in case if it helps, this is the version of my Nastran:
Message 10 of 17
shigeaki.k
Hello @Anonymous ,
currently "part view" only works for parts with solid idealization. An idea has already been submitted to the Product Team to allow for the selection of shell and beam parts in "part view" as per,
Ability to select shell or beam meshed parts in "part view" for result plot
Are you also able to share the model?
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
Message 11 of 17
hi @shigeaki.k,
I can not share it publicly, but I can do it privately for Autodesk support team.
Ali
Message 12 of 17
shigeaki.k
Hello @Anonymous ,
I have sent a private message with regards to uploading the file(s).
Shigeaki K.
Shigeaki K.
Message 13 of 17
shigeaki.k
Hello @Anonymous, thank you. We have received the file. I am wondering if your analysis completed successfully. When I ran the last analysis, I noticed that it was struggling to converge. I removed the "arc length method", and all the contact definitions that you had. I then set up a single "solver" contact with activation distance of 50mm and the analysis seems to be chugging along nicely. I will need to wait until the analysis completes to check the shell von mises results. Regards, Shigeaki K.
Shigeaki K.
Message 14 of 17
hi @shigeaki.k
Unfortunately it didn't converge. I am going to update my model to match your suggestions and check the analysis.
Thanks for your try.
Ali
Message 15 of 17
shigeaki.k
Hello @Anonymous ,
the model completed successfully. In the meantime, could you send @John_Holtz  or myself a link to a file sharing site you are using via private message for this forum.
Shigeaki K.
Shigeaki K.
Message 16 of 17
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
I wanted to follow up with you to find out where you stand with the analysis. Did you get it to work using Shigeaki's suggestion? Did you provide the updated model that is not working? (Sorry if I missed a message somewhere. Smiley Sad)
John Holtz, P.E.
Autodesk, Inc.
Message 17 of 17
Hi @John_Holtz,
Thanks for your follow up. Yes, I got the analysis working. I used @shigeaki.k comments and it worked.
His comments were:
  • use solver contact for contact defenition,
  • avoid "arc mesh method".
I provided the model and he worked on that, too.
Ali
