Hi there,
If anyone could make this more clear to me it would be fantastic.
Let's say I have an object sitting on a tower and it is connected at 4 points directly above 4 pillars. I understand that if I apply a gravity load to my model, my beams will be under their own weight, which is ideal.
However, normally I would just turn my object masses into forces/pressures and apply them as I see fit. I've never used a concentrated mass before. Instead of having a 3 ton object applied as a 29.4kN load central to the beam it's on, could it possibly be more accurate to apply it as a mass and let a global gravity load imply gravity onto the mass which would basically give the 29.4kN? Assuming everything is dead central.
Cheers
