John, you have a lot of experience with programmers 🙂
Yes, the first assumption turned out to be true. The second assumption is not. All the same, they thought about it.
When I changed 0 to a close value, the response appeared. Thank you very much!
But this is a bug and I would like to convey it to the developers. Could you tell me how to do this?
My vibration load is set in one frequency range through displacements, in another through accelerations. Like this:
1 - 10 Hz - 1 mm
10 - 100 Hz - 9.8 m/s^2
Now I suspect that requesting them through two different loads will fail (I tried to do this, but I got false results). What is the best way for me to do this? Translate displacements into accelerations or split into two analyzes with different loads? The next step I would like to calculate vibration fatigue, but I do not yet have experience on this module of Inventor Nastran.
