Warning Message G3057
milani
Message 1 of 9
milani
I updated nastran at 2018 version.
Since when I updated it, in my analysis I obtained this warning message.
I'm sure that the indicated property is referred to a material with a density.
The same model running with autodesk 2017 don't take me this message.
In the nastran .nas file the property referred correctly to the uinque material model.
Can anyone help me?
Best regards
Stefano
Replies (8)
Message 2 of 9
John_Holtz
Autodesk Support
Autodesk Support
Hi Stefano,
Thanks for noticing that the message is occurring with Nastran 2018. I have noticed that message when using In-CAD (which uses the same Nastran solver), but I did not pay too much attention to it. I did not make the connection with 2018.
Have you noticed if the message occurs in all models? Or maybe the warning only occurs when there are certain element types (like rigid connectors or something). I will see if I can locate one of my models with the warning, but any insight would help.
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 3 of 9
John_Holtz
Autodesk Support
Autodesk Support
Sorry, I should have checked ALL of our internal information before posting instead of just checking SOME of it. Smiley Frustrated
It looks like development is aware of the problem, and that it occurs with beam or line elements. So we are "working" on a fix.
John Holtz, P.E.
Message 4 of 9
milani
in my model I have a beam element.... However, the property 14 is referred to a solid property, and this message removed if I set partgeomout=off
Best regards
Stefano
Message 5 of 9
GerryJDail
I have noticed this error message coming with solid element properties as well. It does not always occur, however. I solved a simple problem with no such warnings, but other, more complex models always displays this warning. I assume that unless I am employing gravitational force, this is not an issue? Please confirm. Cordially, Gerry J. Dail, PE
Message 6 of 9
milani
I notice that if I use gravity load the warning occurs but the results include this load.
I however would like to have a confirm from Autodesk
Best regards
Stefano
Message 7 of 9
costanzofa
Is there still a fix in the works for the 2018 version of Autodesk Nastran to take care of this issue, or has this already been implemented?  If not, will there be a patch coming soon to address this?  Thanks!
FAC
Message 8 of 9
KubliJ
Hi FAC,
I am sorry, the issue has not been resolved yet and I do not have an ETA for when the fix will be released.
Sorry for the inconvenience.
James
James Kubli, P.E.
Please marked this as solved if your question has been answered.
Message 9 of 9
costanzofa
Thanks for the response . I'll keep an eye out for a future fix.
