Dear @KubliJ and @John_Holtz ,
Thanks for fast reply!
I know how to choose or set units for analysis. Let's look to static stress analysis - There is no difference what Unit system your use, because you can choose (any from list) result units for contour plot while working with results. Isn't it? I checked it in 2021 release also. Please see image attached for details. But when explicit dynamic analysis is finished then i don't see any unit and can't choose.
After your comments i still don't understand: Is it bug with units in explicit dynamic analysis or impossible to indicate result units in this type of analysis or smth else.
John, you say "In other words, James solution only works when you know what the original unit system was.". OK. But why in results window i have possibility to choose units for contour plot (in static stress analysis for example)?
John, you say "If you change the unit system after the analysis and do not remember what the original units were when the analysis was performed, then you are out of luck." Ok, But if i am working with results or stress report of my collegue for example and i need immidiate information about units he used? In any case units must be indicated in any plots. I hope this fact don't need discussion.
I am going to make presentation "Whats new in Inventor Nastran 2021" for our customers and simulation community. And when i will show explicit dynamic analysis in action then first question for sure will be about units. Stress engineers very attentive persons))
Best regards,
Alexey Vidyakin
