Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
TRAILER analysis
5 REPLIES 5
DWhiteley
402 Views, 5 Replies
TRAILER analysis
Has anyone tried running through the trailer analysis tutorial recently.
It's a bit of a mess!
You cannot easily turn on/off the box section solid.
Once you've got it turned off, you cannot display it again.
Finally when trying to select the mesh elements to add constraints to, you cannot select them.
Oh, and if you do manage to select an edge you then get the "geometry not applied at a valid FE mesh location" when you run the analysis.
Dave
Envisage
5 REPLIES 5
Roelof.Feijen
in reply to: DWhiteley
Hi @DWhiteley,
I just ran the tutorial. No problems at all.
So tell me which version of Nastran In-CAD are you using? Did you apply al available updates?
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
DWhiteley
in reply to: Roelof.Feijen
2018.2 hf1
Roelof.Feijen
Running exact same version. See my screencast. No issues.
Are you sure HF1 was applied correctly?
Have you tried reinstalling Nastran In-CAD?
Roelof Feijen
DWhiteley
There is something strange going on here then, as the whole class had the same problems. I will start again with the latest dataset and report back.
DWhiteley
I opened the trailer frame assembly and not the part Ahhh! sorry guys.
