Symmetry constraint
Symmetry constraint
sigurd.naess
Symmetry constraint
sigurd.naess
Hi!
My model shows large difference in results when using symmetric constraints compared to whole model. My symmetric model fails at 99,7%. What can cause this difference? i'm I applying symmetric constraints wrong?
I have constrained my symetric model in the direction of the global coordinate system
Fix constraints (red area), flange is loaded as indicated by blue arrows (using a force)
Non-linear analysis, E = 200GPa, E_tan = 0, simga_y = 550MPa, sigma_u = 750MPa
John_Holtz
Autodesk Support
Autodesk Support
Hi @sigurd.naess
The mesh is different in the two models, and a nonlinear analysis is sensitive to the mesh.
Try using a different value for E_tan (which I think is your tangent modulus). Values of 0 can lead to stability problems. For example, a bar with 1 mm^2 cross section cannot support a 1 N load of the material properties say that it is perfectly plastic after it yields at 0.5 MPa. There is no strain value on that stress-strain curve that results in a stress of 1 MPa! Your model is obviously more complex, but mathematically something similar could be occurring.
Another option to try is to use more than 5 increments. That might be applying too much load in one step. Try 25 or 50 increments.
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
