Surface-solid connection with continuous meshing fails
Hi again,
(inventor 2021)
I'm trying to achieve continuous mesh between surface and solid bodies following the AU presentation page 7 but it just fails and the surfaces fly away...other than that it looks great.
Is there some sort of parameter I'm missing? I can't figure this out...
My example attached.
If I fix the small surface (T representing the thickness of the plate) the outcome is fine for the loaded surface (but the "wall" plate is ignored):
This means the surface representing T thickness does not hold on to the plate...even though mesh is continuous and even if I apply bonded (offset bonded) contacts between the small surface and the plate.
