Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Summing Radial Reaction Forces
1 REPLY 1
hadley_rossignol
362 Views, 1 Reply
hadley_rossignol
Observer
Observer
I am trying to determine the amount of force that is required to change the diameter of a part by a certain amount. By using enforced motion and a cylindrical coordinate system, I was able to generate the model. However, the reaction forces are split into the reaction force in various radial directions (unsure what the intervals are) and are not the total reaction force, which is ultimately what I am looking for.
Wondering if there is a way to determine this force.
1 REPLY 1
John_Holtz
Autodesk Support
Autodesk Support
Hi @hadley_rossignol . Welcome to the Inventor Nastran forum.
If you are using the Inventor interface, I am 99% certain the reaction forces (SPC results in the contour plot) are in global X,Y,Z. The SPC forces are not in the radial direction. To get what you want, you would need to do the following:
  1. Export the SPC forces in X, Y, Z to a text file.
  2. Get the coordinates of the nodes.
  3. Convert the X, Y, Z SPC force to radial direction based on the position of the node.
  4. Sum the result.
The first two steps can be done with the third-party app FNO Reader. The last two steps would be done in Excel.
Let us know if you have any questions.
John
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
  4. Sum the result.
John
John Holtz, P.E.
