2D Edge to Edge Contact
MohammadZaman
MohammadZaman
Hello
I want to use a 2d surface to surface or edge to edge SEPARATION contact to model a pile embedded in the soil medium (Inventor Nastran ver. 2024). I receive a fatal error (singularity). I do not know what should I do now. I have attached the model and pics. Could you please help me to solve this issue?
Thank you very much
John_Holtz
Autodesk Support
Autodesk Support
Hi @MohammadZaman
You need to use 3D solids because there is no "edge to edge separation" contact with shells. There is nothing holding the center shell in position, so the solver gives a singularity error (E5000, E5001, or E5004) when the part is free to move.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
