Suggested Reading - Tips and Trick
John_Holtz
Autodesk Support Autodesk Support
Message 1 of 15
John_Holtz
Autodesk Support
Autodesk Support
I presented a class at Autodesk University (AU) last week: 60 tips and tricks with Inventor Nastran. The video and handout will eventually be located on the AU website (https://www.autodesk.com/autodesk-university/au-online), but I wanted to make it available now. See the attached.
  • If you are new to Inventor Nastran, I highly recommend reviewing the tips to help get your computer setup, know some important things to do and how, and many other ideas for using the Nastran environment more efficiently.
  • If you are already familiar with Inventor Nastran, there may still be a few new tricks for you.
Here is the table of contents for your convenience:
  • 1) Modeling in Inventor
    • Tip 1. Use Model State
    • Tip 2. Combine parts of assembly
    • Tip 3. Create surface model for shell elements
  • 2) Setting up the environments
    • Tip 4. Display surfaces as opaque
    • Tip 5. Change parameters for analysis
    • Tip 6. Change parameters for current model
    • Tip 7. Change parameters for all new models
    • Tip 8. Prompt for solution with warnings
    • Tip 9. Optimize load/constraint graphics
  • 3) Idealizations
    • Tip 10. Use proper idealization for different geometry
  • 4) Meshing
    • Tip 11. Mesh settings versus Mesh table
    • Tip 12. Which mesh was used?
  • 5) Connectors
    • Tip 13. Multiple connectors in one dialog
    • Tip 14. Rigid vs Interpolation Connector
    • Tip 15. Springs
  • 6) Contact
    • Tip 16. Solver instead of manual contact
    • Tip 17. Hide parts to select “covered” faces
    • Tip 18. Max activation distance (manual contact)
    • Tip 19. Max. activation distance (solver contact)
    • Tip 20. Unsymmetric versus Symmetric contact
    • Tip 21. Friction in contact
    • Tip 22. Deleting contacts
  • 7) Loads & Constraints
    • Tip 23. Face Chain
    • Tip 24. Use Pressure where possible
    • Tip 25. Loads & Constraints in multiple subcases
    • Tip 26. New load or constraint
    • Tip 27. Duplicate load or constraint
  • 8 ) Ribbon & Model Tree
    • Tip 28. How to hide ALL CAD parts
    • Tip 29. How to hide mesh using Mesh Table
    • Tip 30. Hide parts and mesh using Model Tree
    • Tip 31. How to display beam cross-section
    • Tip 32. Show direction or orientation of beams
    • Tip 33. Keep Model branch collapsed
    • Tip 34. How to add a concentrated mass
    • Tip 35. How to copy loads, constraints, and so on
    • Tip 36. What NOT to change from Model branch
  • 9) Running Analysis
    • Tip 37. Activate results output for nonlinear analysis
    • Tip 38. Improve convergence in nonlinear analysis
    • Tip 39. Queue multiple analyses using Nastran Editor
    • Tip 40. Queue multiple analyses using batch file
    • Tip 41. View the warning/errors from analysis
    • Tip 42. E5000, E5001, E5004 errors
    • Tip 43. E5118 warning
    • Tip 44. G3051 warning
    • Tip 45. Add UCS to locate specific nodes
  • 10) Viewing Results
    • Tip 46. Load results for current analysis
    • Tip 47. Review ALL the results!
    • Tip 48. View reaction forces
    • Tip 49. Meaning of moment SPC Summation
    • Tip 50. Fringe and 6 color contour
    • Tip 51. Nodal Probe versus Probe
    • Tip 52. Make XY Plot for results
    • Tip 53. How to hide parts
    • Tip 54. Turn off automatic updating (performance)
    • Tip 55. Turn off undeformed model (performance)
    • Tip 56. FNO Reader to extract results
    • Tip 57. FNO Reader to combine output steps
    • Tip 58. FNO Reader to create new results
  • 11) Help & Other Topics
    • Tip 59. Search Help (or AKN) > Technical Support
    • Tip 60. “List of changes” on Inventor Nastran forum
Edit 2024 Aug 30: uploaded rev 1 of pdf with some enhancements and changes through Inventor Nastran version 2025.1.
John
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Replies (14)
Message 2 of 15
Roelof.Feijen
Hi @John_Holtz ,
Great handout. Definitely recommended for new and experienced users of Inventor Nastran. Looking forward to the video on AU.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 3 of 15
admaiora
Thank you @John_Holtz !!!
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 4 of 15
vanderson.mapdata
Dear @John_Holtz
Really interesting class and handout!! Thanks so much for sharing with us.
There are many tips that will help me in my models and I will share some of them in my Nastran training.
Regards
Message 5 of 15
trung.pham2AHCC
Thanks for great tips!
Message 6 of 15
Alberto_Pérez_Parra
Hi @John_Holtz,  I would like to grow in my knowledge in Inventor Nastran, Do you have a book/publication? or any kind of information you could provide me to develop my skills, level of expertise. I'm planning to promote the use of Autodesk Nastran in my community developing courses/workshops to my engineering students and local sugar cane mill engineers. Thanks for your advice.
Ed.D.& M.Eng.Alberto Pérez Parra.Mechanical Engineer and Designer, Instructor, Professor and CAD/CAM/CAE/CFD Enthusiast, México.
Design Proeficency
Let me know that my help was useful clicking: "Accept as solution" button, thanks. Info. and contact: |Twitter|LinkedIn| Credly|.
Message 7 of 15
John_Holtz
Autodesk Support
Autodesk Support
Hi @Alberto_Pérez_Parra
The latest book that I am aware of is "Up and Running with Inventor Nastran" by Wasim Younis. There are a number of volumes depending on the year (maybe only 2023 is available?) and nonlinear or static analysis. There may be other books available.
John
John Holtz, P.E.
Message 8 of 15
Alberto_Pérez_Parra
Yes, the  "Up and Running with Inventor Nastran" by Wasim Younis books are good source. I have both, even the spanish translation. I hope to find different/new information, thanks for your advice @John_Holtz .
Design Proeficency
Message 9 of 15
dainalthomas01
Observer
Observer
Thank you! This summary is very helpful, especially the detailed insights on the 60 tips and tricks. I appreciate the focus on assisting new users. I look forward to the video and handout on the AU website for more learning.
Message 10 of 15
martin_brunnerCQUCF
Observer
Observer
Hello John
I will step throuth the handout. Looks very helpful.
Thanks for your help
Martin
Message 11 of 15
ecottingham3KD7X
Hi John
Awesome, article.  Thank you very much.
In Tip 3: Create Surface Model for Shell Elements on Fig 5 & 6 you are showing "surface model" and "Solid Model" analysis.
How are you doing this?
Message 12 of 15
John_Holtz
Autodesk Support
Autodesk Support
Thanks @ecottingham3KD7X
Figure 5 (a solid model transferred to Nastran, then converted to shells) was created using the "Prepare > Midsurfaces" command. Because the "solid" portion of the web only extends to the inside faces of the flange, the midsurface of the web is the same height as the distance between the flanges. The midsurface for the flange is at the mid-thickness of the flange. This is where the gap between the web and flange happens; the gap is equal to half the flange thickness.
Figure 6 is a surface model created in Inventor. I may have created the surfaces directly (sketch 3 lines for the web and 2 flanges) and extruded those to make 3 surfaces, or I used the forum post How to convert a solid model to surfaces - Autodesk Community to convert a solid model into a surface model.
John
John Holtz, P.E.
Message 13 of 15
ecottingham3KD7X
Hi John
In  Tip 3 figure 5 - Solid Model created in Inventor converted to surfaces in Nastran the Analysis is labelled Solid Model with the Model State set to Master.  So the Master in the model is the Solid Model?
In  Tip 3 figure 6 - Surface Model created in Inventor used to create shell elements in Nastran.  The Model State is set to Surfaces.
In your "How to convert a solid Model to surfaces" the surfaces are "created" into a different assembly than the solid model.  How are you able to select a different Model State between the files?
Thx
Eldon
Message 14 of 15
John_Holtz
Autodesk Support
Autodesk Support
Hi Eldon.
The surface example shown in the "Tips and Tricks" document was created manually, meaning I projected a sketch from the solid, drew lines for the surface geometry, and then extruded the lines to create the surfaces.
You are correct that the procedure in "How to convert a solid Model to surfaces" is creating a separate model, not a separate Model State. In a simple model (like in this example), it may be practical to use the model state. In your complex example, it may not be practical to use a different Model State for the solid model and surface model.
I am open to suggestions from our Inventor experts. (I can draw an I-beam, but that is almost the limit of my model creation skills. 🙂)
John
John Holtz, P.E.
Message 15 of 15
naqib_mashrur4YFQQ
Hi John. Thanks for making this great resource for using Inventor Nastran. I am sharing the link to the autodesk university video here, since I couldn't find it anywhere in this thread. I hope it will be helpful to anyone reading this post in the future.
