a static acceleration of 5 g will be applied on my model ,which type of analysis and type of load should i be choosing?
I tried using explicit dynamics and enforced motion-acceleration as a load but i am getting unreasonable results. should i put the enforced motion on the whole model and then constrain it ? or only at 1 face and also constraining the same face?
Also my model is a part of a bigger model that connected to it using bolts , so the 5 g acceleration will be applied to the model but the hold points are at another model connected by bolts. should i only add constraints at the location of the bolts?
What i am trying to calculate is if the bolts will withstand such an acceleration or not.
Best Regards,
Omar Nimer
