Rigid Body Modes with Parabolic Mesh?
Simple 2-part assembly.  1 part fully-constrained, the other part has no constraints or bonding (by intention to test rigid body modes).
Works fine with linear mesh - first 6 modes are <=0.  Setting the mesh to parabolic results in fatal error E5001.
Replies (7)
John_Holtz
Autodesk Support
Autodesk Support
Hi Mark,
I will take a look at the model to see what I can figure out.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Thanks, John.  Marwan just emailed me and confirmed it is an issue.
John_Holtz
Autodesk Support
Autodesk Support
Just to explain the model to other readers, the assembly consists of a cantilever beam (fully fixed on one end) and a block. As Mark explained, the block is not connected to the beam -- it is completely free. Therefore, a modal analysis should detect 6 rigid body modes at a frequency of 0. Mode 7 should be the first vibration mode of the beam, mode 8 would be the second vibration mode, and so on.
Here are a few things I found.
  1. The error would occur when using parabolic elements at some mesh sizes but not other mesh sizes.
  2. When the analysis would run (such as at a mesh size of 0.1), some of the six rigid-body modes were skipped. Modes 1-4 were the rigid body motion of the block. Mode 5 was the "first" vibration mode of the beam.
The work around is to set the "Modal Setup > Extraction Method" to "Subspace Iteration". When this is done, the analysis runs successfully with the parabolic elements.
(edited. I noticed that the description of "thing 2" was incomplete Smiley Sad)
John Holtz, P.E.
Should subspace be the default method then if the parameter RIGIDBODYMODES is set to AUTO or FORCED?
John_Holtz
Autodesk Support
Autodesk Support
Hi Mark,
I just wanted to make sure the work-around of using the subspace iteration worked for you (and more importantly, for the real model). If so, I will mark this as "solved".
As for the program defaults, I think the developers will attempt to fix whatever the problem is with the default solver rather than using the subspace method.
John Holtz, P.E.
jayesh.shinde
Hi @John_Holtz,
I am facing similar issue in linear static analysis. I am doing analysis for Pipe (midsurface) with flange (solid). Is there setting in linear static with parabolic mesh?
Thanks, Jayesh
John_Holtz
Autodesk Support
Autodesk Support
Hi @jayesh.shinde
I think the only similarity is the error message. Linear Static versus Normal Modes are completely different analysis types, and the error message is caused by completely different reasons. See my reply to your post https://forums.autodesk.com/t5/inventor-nastran-forum/offset-surface-of-pipe-to-solid-pipe-flange-co....
John
John Holtz, P.E.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
