Announcements
Internal Error Detected in Module
sigurd.naess
sigurd.naess
Hi!
I'm getting the following error when running my analysis:
My analysis is a duplication of a shell model non-linear analysis that ran just fine
Only changes are:
- Kinematic material model (plasitc material)
- 8 subcases cyclic the loads from 100% to 0%  and so on
My wish is to plot sigma1 vs epsilon1 to check for strain accumulation
Any thoughts on how to bypass this error?
Regards
I'm using Nastran 2022:
salih_kapucu
Hi @sigurd.naess
Could you check the mates in the support, load and analysis section?
vanderson.mapdata
Hi @sigurd.naess
Error S1117 could be generated from some causes in models:
SuperelementContact or Mesh.
I see your model and you have some edge to surfacecontacts. Try generate continuous mesh instead of using contact. It could help you with this model.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
sigurd.naess
Hi @vanderson.mapdata @salih_kapucu
Funny thing, I made a new analysis and repeated the same steps when setting up my model and it ran fine when using 8 subcases to cycle the load, but when adding more subcases the same error appeared.
(My results for one node 😁)
@john.holtz are you aware of any limits to the number of subcases in a static non-linear analysis, that would explain the S1117 error?
Thank you!
Regards
John_Holtz
Autodesk Support
Autodesk Support
Hi @sigurd.naess
That is a neat graph!
I am not aware of any limit to the number of subcases in a nonlinear analysis, but I have probably only used 3 or  4 subcases maximum.
How much free space does the C: drive have before you run the analysis? I see from the output tab that the C: drive has 76 GB of free space. That is probably enough free space for a model that size, but I have seen some models (monster models) where 700+ GB of disk space gets used. It's possible the internal error is related to free space. The misleading thing is after the analysis fails, the temporary files are cleaned up, so it may look like the drive has a lot more free space than when the analysis is running.
The other possibility is there is something in the model that leads to the internal error. If you can post your model, I will run it here. (Zip the assembly and part files and attach them.)
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
