Results from output (Autodesk CFD(.cdFst) in Autodesk NASTRAN - Result set and nodal load missing
while performing Fluid structure interaction problem in Autodesk NASTRAN when I select Load type from output of Autodesk CFD it doesn't show result set such as temperature or pressure and also nodal loads.
Kindly provide the detail why this issue is happening.
