Results from output (Autodesk CFD(.cdFst) in Autodesk NASTRAN - Result set and nodal load missing
tarun.bhardwaj
tarun.bhardwaj
while performing Fluid structure interaction problem in Autodesk NASTRAN when I select Load type from output of Autodesk CFD it doesn't show result set such as temperature or pressure and also nodal loads.
Kindly provide the detail why this issue is happening.
John_Holtz
Autodesk Support
Autodesk Support
Hi @tarun.bhardwaj
I suggest that you define an Idealization in Nastran, and maybe generate a mesh. Essentially you have told Nastran that you want to have no model. My guess is Nastran thinks there is no reason to import loads from another source when there is "no model".
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
tarun.bhardwaj
Hi John,
I run CFD analysis first and then I use that output as a loading condition in Autodesk NASTRAN.
I am using the Latest version i.e. 2023 for both CFD and Autodesk inventor.
John_Holtz
Autodesk Support
Autodesk Support
  1. What did you choose for the Idealization in Nastran? Solid? Something else?
  2. After you define the Idealization in Nastran and generate the mesh, can you select a load from a CFD analysis?
If you cannot choose the load after defining the idealization, I will have someone test version 2023.
John
John Holtz, P.E.
Autodesk, Inc.
tarun.bhardwaj
Hi @John_Holtz
1. I choose SOLID  for the Idealization in NASTRAN
2.After I define the Idealization in Nastran and generate the mesh.
After that I load the result from output file .Cfdst.
wlodzimierz_dzygadlo
Hi John
I have the same problem with Inv. Nastran 2023 and file from CFD 2023.... It's not working like in the past 😥
John_Holtz
Autodesk Support
Autodesk Support
Sorry that this post did not get updated. There is another forum post or an article somewhere that indicates reading results from CFD does not work in Inventor Nastran 2023.
John
John Holtz, P.E.
Autodesk, Inc.
