Result interpretation from Bolt - connectors
lucmartzz
lucmartzz
Hello everyone,
I'm exploring some results from the use of bolt connectors. On the dropdown menu I see a lot of beam related plots but I would like to know more precise which one is the correct at the moment of do a correct interpretation.
Thanks!!
JaSar24
Yeah, that's really confusing and not user-friendly at all...
John_Holtz
Autodesk Support
Autodesk Support
Hi @lucmartzz
Instead of trying to describe the dozens of results for beam elements listed on the page Autodesk Inventor Nastran 2022 Help | Beam Element Results Column Descriptions | Autodesk, can you clarify what result you are trying to find?
You may need to output the FORCE results so that you can look at the forces and moments in the element.
John
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
lucmartzz
@John_Holtz thanks for getting back. Well, I just want to determine from the results if the bolts that I'm using are suitable for resist the shearing force or any results that can help with that. I did analytical calculation and compared with bolt generator calculations, unfortunately those are not matching, so I want to figure out with FEA if I can get more conclusive results.
Thanks in advance for your help
Esteban M
John_Holtz
Autodesk Support
Autodesk Support
To get the shear force in beam, you want to output the FORCE results: "Analysis > Edit > Output Controls > Force". Then you will be able to view the result "Beam Diagram > Shear Force".
Also see these articles which have some details:
John
John Holtz, P.E.
lucmartzz
I did a tutorial, I hope it is useful for the community
https://youtu.be/UAk9mUe9Ya4
