Questions about Thermal Analysis Inputs
Hi All,
I have what I hope are a few simple questions. I'm having no luck finding answers to them in the documentation. For Autodesk Inventor Nastran 2023, when performing a nonlinear transient heat transfer analysis:
1) What does the thermal constraint do?
2) How does the applied heat flux condition work? If I'm applying it using a table of heat flux magnitudes that change over time, do I need to put an initial value of magnitude in the entries, or is completing the table sufficient? I'm getting values of heat added to the model that don't make sense relative to what I think I'm applying.
3) How does the initial temperature condition relate to other applied heat loads? Does it create an initial uniform temperature for all bodies in the analysis and then permit the temperature in the materials to go to zero over time unless they receive another heat input? Or does the initial temperature condition set the floor for the temperature in the model?
4) Is there a way to plot the temperature through a wall in a model as a function of distance?
Thanks in advance for any help.
Best Regards,
Chris
