Hi @mcook21VD9DL
The number of possible arrangements and input is vast. I suggest that you do some testing on your arrangement to confirm that it is behaving as you want it to. (The contact force should indicate where nodes are connected. Although this does not indicate what the node is connected to, you will at least know if nodes that should not be connected have a contact force.)
Just to clarify for everyone's benefit, there are three commands in the ribbon for contact: Auto, Manual, and Solver.
- "Manual" contact requires the user to select the geometry that is in contact, and define which is the master and which is the slave.
- "Auto" creates a manual contact based on which faces of the CAD parts are touching. Auto does not creating anything different than what the "Manual" contact produces.
- "Solver" will search the entire model (or only selected geometry) and create contact.
Now to your questions.
My understanding is that the nodes (and maybe the elements) that have contact elements created by manual contact are not available for use by the solver contact. So the edge-to-surface contact identifies the nodes along the edge, and these nodes cannot be used in the solver contact. (Perhaps the entire element connected to the edge cannot be used in the solver contact. A test model would need to be created to confirm that.) Naturally, this does not prevent the other elements on the face from being connected to the other surface. The best way to prevent excessive contact is to limit the maximum activation distance. See Understanding maximum activation distance and contact type in a Simulation.
- Edge 2 and Surface 1 are in contact using manual contact. Only node A will be connected to face 1.
- If solver contact is defined (either specifying surfaces 1 and 3, or not specifying any regions), then node A will not be connected to surface 1 by the solver contact. I do not know about node B which is on the same element as A. Nodes C and so on can be connected to surface 1 if they are within the maximum activation distance.
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided, indicate the version of Inventor Nastran you are using.If the issue is related to a model, attach the model! See What files to provide when the model is needed.
