Problem with bonded contact changing stiffness of non-contacting parts of model
gordon.fox
gordon.fox
I am having a problem where applying a bonded contact to one part of a model is stiffening other parts of the model that shouldn't be affected. I have been able to recreate this behavior is a simplified cantilever beam model. Has anyone else seen this? Is there some way I am setting my model up incorrectly?
The simplified model that shows this problem is a cantilever beam, fixed on the right end, and with a load at a point in the middle. Applying a bonded contact to the "outside" of the load application point drastically changes the deflection of the beam, which it should not. I first modeled the two parts as one solid in model "H Assy.iam". The deflection of H at the load application point is about .087 inches, which matches analytical calculations very well.
Then I modeled it as two parts bonded together, "F G Assy - Shows Problem.iam", and the deflection at the load application point is only .058 inches, significantly different.
If anyone has seen this issue before, any help would be appreciated!
Thank you.
John_Holtz
Autodesk Support
Autodesk Support
Hi @gordon.fox
From a forum post last week, use Offset Bonded contact instead of bonded contact when the model has curved surfaces bonded together.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
gordon.fox
That fixed it. Thank you so much!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
