Inventor Nastran Forum
Welcome to Autodesk’sInventor Nastran Forums. Share your knowledge, ask questions, and explore popular Inventor Nastran topics.
Pressure along side of shear element
1 REPLY 1
eli1265
164 Views, 1 Reply
Im trying to apply pressure on a hopper of a silo. I want pressure in normal direction and along side (shear) of the shell element. I can not seem to get the right direction on the pressure acting along the element . Any ideas?
How it is now:
How I want it to be:
Thank you!
1 REPLY 1
John_Holtz
in reply to: eli1265
Hi @eli1265
You need to calculate what the components are and enter those values using a cylindrical coordinate system.
In other words, the normal pressure and shear pressure are vectors. When combined, they are a new vector oriented in some direction. This new vector can be broken into a radial component and axial component which can then be entered on the pressure dialog.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Technology Administrators
