Hi there,
I am working on a project to determine how many cap screw will be required to hold a flange (20mm thick) on a pressure tube and I would like to calculate the axial stress generated in the screws.
I am using M12x 50mm long cap screws on a circular pitch with a 2mm thick washer 24mm in diameter and I am attempting to use the bolt connectors in Inventor Nastran 2022.
I have split the surface of the gland to account for the washer diameter (24mm) and I have also split the surfaces in the tapped hole to ensure correct length of the bolt (50mm in total)
I have a few questions regarding the inputs required:
a) Diameter of the bolt - would this be the major diameter of 12mm or would I calculate a diameter based off the thread stress area (84.3mm^2 for M12) and arrive at 10.36mm ?
b) What value would I use for the Useful Length? Would this be 50mm as I am using a 50mm screw ?
I look forward to your assistance. Thanks
