Pipe Clamp Under Bolt Pre-Load study
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all I am looking for some help with a study I am currently conducting.
For context I have two clamps which clamp around a pipe with a rubber liner between the clamp faces and pipe under a specified bolt pre-load using connectors (image attached). I am then applying a moment on the clamp to try and establish what bolt pre-load is required to prevent the clamp from slipping around the pipe.
My current study settings are:
Analysis Type : Non-Linear Static
Connectors : Bolts
Surface Contacts : Shrink Fit/Sliding
Mesh Element Size : 15 mm
Load : Moment
Constraints : Pipe = Fixed Constraint
I am currently unsure on whether I am using the correct constraints and contacts and if anyone has any suggestions on how to improve my study.
When I am currently running my non-linear static analysis because of the shrink fit/sliding contacts currently applied, I encounter an E5076 error so any help with my study on how to correctly set it up would be appreciated.
I have attached images with all my study settings.
